| I am using the centric rotors now. I would think that if the holes are spaced wider, once the lug nuts are tightened down, there won't be any slop and movement. I will check the shims for the pads. I will most likely remove the 350z brake upgrade and go back to stock to further diagnose the problem. This project should not have this much hassle. Thank you
 <<< Slow in & Fast out >>> |
